camlesse
byVar
Please excuse the simplicity of the request.  I am trying to use a column formula to determine the quintile for a column of values that are divided into specific groups in another column.  The data look something like this:
ClassYearClassRankQuintile
2010
1
20102
20103
20104
20105
20111
20112
20113
I want the formula in the quintile column to determine in what quintile the class rank is depending on the year.  I cannot get the correct syntax in the formula to make the calculation.  All attempts to use Quantile [;ClassRank, :ClassYear] result in only Class Rank appearing in the column formula.  Any suggestions?
ron_horne
Re: byVar
ron_horne
Re: byVar
hi camlesse
follow this path:
Calculating Col Quantile by columns
Best,
ron
camlesse
Re: byVar
Thanks Ron.  Very helpful!
Re: byVar
The Summarize() function is also simple to use but quite powerful when you have a By variable to consider.
