Kip1
adding lsd lines in graph builder JMP Pro 15.2
JMP enthusiasts,
I am wondering if there's anyone here who knows how to add LSD lines in graph builder. I have a bar graph with three levels of variable A. For each level of A, there are six levels of variable B overlaid such that each level of A has six bars arranged in descending order of magnitude. LSDs for each level of A were calculated in SAS. I want to add a line or error bar representing the LSD range, visible in the same location in each panel. Is this possible? GUI tricks or scripting solutions are welcome.
Thank you in advance
Ressel
Re: adding lsd lines in graph builder JMP Pro 15.2
Maybe this can help you a little on the way to creating custom error bars.
Kip1
Thanks for the link and introduction to JMPer Cable. This may do the trick.
