sam_t
add blank page with text on PDF output
How can I add a blank page with some texts between plots. See the code below.
Thanks.
dt = Open( "$SAMPLE_DATA/Football.jmp" );
wf=new window("final");
wn = New Window("Bivariate",
			Bivariate(Y(:Name("Height")),
			X(:Name("Weight")),
			Histogram Borders(1)));
wf << append(wn);
// add a blank page here with some text?
wn = New Window("Bp", Bubble Plot(Y(:Name("Height")), X(:Name("Weight")))); wf << append(wn);
wf << set Print Headers( "", "", "" ); wf << Set page setup( margins( 1, 1, 1, 1 ), scale(1), portrait(0), paper size("Letter") ); wf << Save PDF("C:\JSL\final.pdf"); wf << Close Window; wn << Close Window; dt << Close Window;
Re: add blank page with text on PDF output
Add a page break in the New Window using the Page Break message
wn << page break;
Check out the documentation in the Scripting Index.
wn << page break;
