Is there a statistical shortcut in JMP to calculating Z-prime (Z') or SSMD (strictly standardized mean difference)? I'm searched around but I keep getting sent to trainings on Z-score.
Created:
Nov 8, 2023 04:55 AM
| Last Modified: Nov 8, 2023 2:09 AM(2277 views)
| Posted in reply to message from JB4 11-07-2023
Hi @JB4 : I see no single JMP function for this, but it should be easy enough using functions for sample means and sample standard deviations (see links below).
The Z-factor is a measure of statistical effect size. It has been proposed for use in high-throughput screening (HTS), where it is also known as Z-prime, to judge whether the response in a particular assay is large enough to warrant further attention. In HTS, experimenters often compare a large ...
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '695394' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '695394') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '695394') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
