hogi
Level XIII
X & Y Group: maximum number of levels in view?
I just noticed that in Graph  Builder, even when the levels in view for X & Y group are set to All, there are just 8 levels displayed  for X Group and 30 levels for Y Group. Specifying larger numbers in JSL  via
N View Levels( largeNumber)
did not help.
Is there some alternative way to increase the number of levels in view for X and Y Group?
A big drawback o the current restriction:
Make Into Data Table just generates images for the displayed levels. Levels, which are not displayed are ignored (!)
Re: X & Y Group: maximum number of levels in view?
Could the page count limit be affecting all of those? I think by default it is set to 200 (or something similar)
hogi
Level XIII
The "8" and "30" don't seem to be fixed numbers, but - unfortunately - "always" less than I need.
Today for another data set it's 9 and 25  and I would need 15 and 35.
By the way: everything is fine when I remove the "page" variable: all groupBy entries visible.
After adding page again, the entries are restricted.
So, there seems to be a maximum number of subplots:
N = # X Groups times  # Y Groups times # pages
where Jmp decides that this is just too much and restricts the levels for the levels in view.
Hm ....
