Gareeeesh
X Axis Settings on Variability Plot?
Hi all,
Since JMP 13.2 I have been unable to edit the X Axis settings on Variability charts - is this intentional? I have JMP 14 now and it still has the same issue.
I know you can show separators but I liked the ability to have minor/major divider lines on charts where I have mulitple X axis variables shown.
Cheers,
Gareth
Re: X Axis Settings on Varaibility Plot?
I think you should add this to the JMP Wish List
Gareeeesh
Hi Jim,
Thanks for replying. Any idea why this was done away with for Variability charts specifically?
Thanks,
Gareth
I do not know.  If the change was not noted in the JMP 13 enhancement notes then you will have to contact JMP directly.
