aserino
Working with multiple queries simultaneously
I'm attempting to work with two pre-built query builder queries simultaneously. I'd like to eventually be able to plot the data from one ontop of the other using graph builder, however the code below is throwing an access or evaluation error on dtGroup and dtTarget.
Group = Open("C:\Temp\Group$.jmpquery", Private );
Target = Open("C:\Temp\Target$.jmpquery", Private );
Group << Run Background(
	On Run Complete(
		dtGroup = queryResult;
Target << Run Background(
	On Run Complete(
		dtTarget = queryResult;
dtGroup << New Column( "ExGroup",
	Numeric,
	"Ordinal",
	Formula( :Data )
dtTarget << New Column( "ExTarget",
	Numeric,
	"Ordinal",
	Formula( :Data )
I've tried making the variables global  (global:dtGroup = queryResult;) but the same error occurs. Any idea how to use both? Is it a scope/namespace issue?
Thanks!
aserino
Re: Working with multiple queries simultaneously
This would work, however, I'm unsure how to then perform functions using the data from both queries. Also, queryResult is built into the query  On Run Complete() function.
After some troubleshooting and getting some expert advice, the problem has to do with the queries not finishing before the script moves onto the next command. To solve this, I would need to change the Run Background() to Run Foreground().  I've tested it out now and it works great.
gzmorgan0
I cannot see where you have defined query result.  Try the syntax in the attached script.
dtGroup = Group << Run Background(
	On Run Complete(
	    Numeric,
	    "Ordinal",
	    Formula( :Data ) // this assumes there is a column name :Data in your query
dtTarget = Target << Run Background(
	On Run Complete(
	    Numeric,
	    "Ordinal",
Here is a similar example, created and tested for JMP sample data Big Class.jmp.
Test = Open("C:\Temp\test.jmpquery",private);
dtTest = Test << Run Background(
	OnRunComplete(
	  New Column( "ExTest",
	    Numeric,
	    "Ordinal",
	    Formula( :age ) // this assumes there is a column name :Data in your query
aserino
gzmorgan0
Congratulations!
