PhDer
Whats the best JMP stats book for a beginner?
Could someone please recommend a book for using JMP, ideally one thats for novices.
Thanks in advance.
Re: Whats the best JMP stats book for a beginner?
I would check the documentation you can find from here JMP Documentation . There is also quite a few books in SAS Institute SAS Institute - Search results for JMP , but I'm not familiar with these
PhDer
P_Bartell
Level VIII
Here are my two thoughts:
1. If you have to have a book, a physical book, then I'd start here: Statistical Thinking
The book focuses on how you think...before you start fumbling with collecting, analyzing, and reporting your data findings. Then it moves into methods and execution in JMP. But if push came to shove on my Mt. Rushmore of statistical thinking books, nobody tops Don Wheeler's "Understanding Variation the Key to Managing Chaos" book. Wheeler's book does not include any JMP content...but if I could design an optimal book based curriculum, I'd start with Wheeler, then move to Snee et. al.
2. Now, if you are a bit more flexible in terms of your delivery and educational experience options, I can't recommend strongly enough the SAS "Statistical Thinking for Industrial Problem Solving" online course. It's free. Basically assumes you know very little about statistical methods and nothing about JMP. All you need is a web browser and internet connection. You don't even need JMP...in the exercises you run JMP on a virtual machine that is interwoven into the user experience. Here's a link to the course landing page: Statistical Thinking for Industrial Problem Solving
PhDer
Thanks for taking the time to reply, and I will definitely check out the books plus the online course.
P_Bartell
Level VIII
The other thing I'll add is wrt to Wheeler's book and JMP capabilities, is Wheeler's ideas and methods are very congruent with JMP capabilities and design. Indeed there are whole sections of JMP (especially in the Measurement Systems Analysis space) where Wheeler's very methods are codified in JMP capabilities.
PhDer
Thanks again
There are several. Please see
You can see the entire list for yourself here.
