TCM
TCM
What is Quality as a measure in Multiple Correspondence Analysis?
This is a continuation of a project the result of which has been met with approval.
Context: Multiple Correspondence Analysis was done on questions from a survey in 7 countries.  We were able to extract insights on by-country responses to the grouped questions (the responses are supercategories T2B, Neutral, B2B).  There are a few questions posed:
Questions: 1) Is the Quality statistic a measure of response homogeneity, i.e., how consistent the consumers in the country responded to the question?  If so, it would lead us to make some assumptions about the country.  The JMP library does state quality is an indication of how well the point (the country in this case) is represented in the dimensions. [I am having a hard time understanding what this means in the real world].  Appreciate further explanation.
                  2) How is Quality calculated?  (I can't get to the Quality values in the table with the other givens below).
Table 1: Singular Values
Singular ValueInertiaChiSquarePercentCumulative Percent
0.183060.033511717959.6159.61
0.108710.01182605821.0280.63
0.066330.004422557.8388.45
0.047530.0022611584.0292.47
0.041380.001718783.0595.52
0.037760.001437312.5498.05
0.033090.001095611.95100
Table2: Summary Statistics
COUNTRYQuality(dim=2)MassInertia
C0.989510.124970.44327
F0.720690.125090.07058
G0.556720.124970.1194
I0.549830.125090.06586
R0.951290.124780.15764
S0.313920.124970.03898
U0.415430.125030.04796
A0.567780.125090.05631
Table3: Partial Contributions to Inertia for Row Points
CategoryDim 1Dim 2Dim 3
C0.728430.02110.01593
F0.069950.043620.03728
G0.102990.024190.61815
I0.013180.134870.20306
R0.007720.691530.03045
S0.006390.040080.07791
U0.03290.001490.00725
A0.038430.043110.00998
Thank you in advance for any help!
Re: What is Quality as a measure in Multiple Correspondence Analysis?
Hi TCM,
From towards the end of the JMP help section for MCA, there's a section that (potentially) answers your questions:
Quality is the ratio of the squared distance of a point from the origin in the space defined by the specified number of dimensions to the distance from the origin in the space with the maximum number of dimensions. For the Chi-Square metric, a point’s quality in a given dimension can be obtained from the cosine that its vector makes with the vector that defines the dimension. Quality is also equal to the ratio of the sum of inertias in the specified dimensions to the sum of the inertias in all dimensions. Quality indicates how well the point is represented in the lower-dimensional space.
There are also similar explanations of mass, inertia, and relative inertia. Hope this helps.
Hi TCM,
TCM
TCM
Apologies for the late response:  I was out...
Yes, I did see that paragraph.  I tried to follow it in my attempts to calculate for myself where the quality values came from.  Still didn't get to the reported values :(.  Surprisingly, I didn't see a lot of info out there in the www.
Appreciate your help.--tm
