WMS Server Slow
Attaching a webserver image map into the graph builder is extremely slow on my M1 MacBook Pro. This seems as if it may be an issue with the MacBook and how it generates graph builder. Does anyone know how to make the maps low resolution so they would run faster? My best guess why maps don't load (and they load on my Windows) is that the resolution ends up being too high off the bat.
M. Dereviankin
Jeff_Perkinson
Re: WMS Server Slow
Can you give some examples of what "slow" is like? I just tried the San Francisco Crime data (from the Sample Data Library) and found the performance to be acceptable.
I zoomed in multiple times and moved around with the Grabber/Hand tool. The updates were within a second or two.
Are you finding something different from that? What are the comparisons with your Windows machine? How is the timing different?
-Jeff
Craige_Hales
Re: WMS Server Slow
Also, JMP version? I think the street map technology may have been updated.
Craige
