kevinliu
Variance component for censored data
Not sure if this is a question more related to the statistics or the platform. Will appreciate any inputs here!
When we are dealing with variance components studies, all of our factors will be random factors. When we fit such a model using the Standard Least Squares in fit model platform, JMP can give us the REML Variance Component Estimates table. So we can get our result here(Mainly the percentage of each random factors). However, when we are dealing with censoring data(for survival analysis), JMP are not allowing any random factors existing in the model due to model restriction.
My question would be is this due to the model limitation like we cannot do this kind of variance component analysis for survival analysis assuming all of our factors will be random factors(censoring data)? Also I am wondering for survival analysis especially when we are using Weibull distribution, is there a rule of thumb like the failure percentage(non-censored data proportion) should be greater than a certain number? like 60%, 70%, etc...
Thanks
peng_liu
Re: Variance component for censored data
As @eclaassen pointed out, there are methods/tools to do survival analysis with random effects. You might be interested in this SUGI paper: Generalized Linear Mixed Model Approach to Time-to-Event Data with Censored Observations . But the JMP does not offer such tools in the current release. Please pay attention to her new platform in the coming release.
Besides GLIMMIX type tools, Bayesian inference might be a different approach. I am working on a new Repeated Measure Degradation platform, which models random subject parameters using Bayesian inference. The platform itself is not relevant to what you need now, though the technology can be applied.
For you rule-of-thumb question, a major concern is how censoring affects your objective of the analysis. There are two things about censoring that you may need to worry about: how many censored observations occur, and when (or where) censored observations occur. A worrisome situation might be that you have a right censored data with large amount of censored observation, while you are interested in failure probability far beyond the censoring time. But it is not worrisome, if your interest is in the failure probability before censoring time, and you still have a large amount of failure observations, even though censored proportion is big.
In the case that censoring has a great impact on your results so the results have great uncertainties, one needs to put very strong assumptions, either about a specific model, or about one or more parameters.
A classic method known as Weibayes provides a useful approach when almost all observations are censored. In addition to that method, Bayesian inference is another and more comprehensive approach to handle heavy censored data. JMP Life Distribution and Fit Life by X platforms provide these methods accordingly.
eclaassen
Hi, Kevin,
I can't speak to the second part of your question (the rule of thumb) because I'm not a survival analysis expert. I hope someone else can assist you there!
I can speak a little about the first part. At this time, JMP (and JMP Pro) can only do a variance component analysis like you mention from the Standard Least Squares or Mixed personalities within Fit Model when the response distribution is Gaussian/normal. Unfortunately, for survival analysis, the response distribution is non-Gaussian (whether it's Weibull, Exponential, etc), and the survival platform options (Survival or Parametric Survival) do not allow random effects (as you noticed). There are plans for a Generalized Linear Mixed Model platform for JMP Pro that could enable this sort of analysis. The initial scope for that platform does not include the survival distributions, though they are listed for future development. Survival GLMMs are a very active research area!
In the meantime, I don't know if you have access to SAS PROC GLIMMIX. I know that it has the capabilities for this sort of analysis. The book "Generalized Linear Mixed Models: Modern Concepts, Methods and Applications" by Walter W. Stroup has an entire chapter devoted to analyzing Time-to-Event data using PROC GLIMMIX. It could be a useful reference for you.
-Elizabeth
kevinliu
Thanks!
peng_liu
