jb
jb
VBA - Save Excel workbook as JMP data table
Hello, I'm familiar with Excel VBA but new to JMP scripting. I'm currently using JMP 11.
I'd like to open an Excel workbook (with a single worksheet) and save it as a JMP data table, so I can run a JMP analysis on it.
How do I reference the unsaved JMP data table created by this VBA code?
Dim app As JMP.Application
Dim doc As JMP.Document
Dim dt  As JMP.DataTable
'Start JMP
Set app = CreateObject("JMP.Application")
app.Visible = True
'Open Excel workbook containing single sheet of data
app.OpenDocument ("C:\jmp\Data.xlsx")
When I prefix the last line with "dt = ", I get an error.
Any suggestions would be appreciated.
Re: VBA - Save Excel workbook as JMP data table
You should be able to do:
doc = app.OpenDocument ("C:\jmp\Data.xlsx")
dt = doc.GetDataTable();
The sample programs included with your JMP install can help you, the Data Table sample in particular.
Brian Corcoran
JMP Development
jb
jb
OK, I got it to work:
'Start JMP
app.Visible = True
'Open Excel workbook and save as JMP data table
Set doc = app.OpenDocument("C:\jmp\Data.xlsx")
doc.SaveAs ("C:\jmp\Data.jmp")
Brian Corcoran
JMP Development
jb
jb
Thanks, Brian. This is was just what I needed.
Super easy to do in JSL.  Here is some example code for one way to approach this.  Copy the code into a new JSL window (under File > New...) and click the run script at the top of the window.
Names Default to Here(1);
dt = Open();
dt << Save As("Excel Data.xlsx");
Hope that helps you out!
M
