MathStatChem
Using "<" and ">" as normal text when using Markup with a Text Box
 Is there a way to display "<" and/or ">" as normal text in a Text Box.  For example, the script below gives an error, it is interpreting the < and > characters as parts of an HTML tag.
names default to here(1);
string = "the value is <b> <<a </b>, but <i> > b </i>";
new window("test",
	text box(string, <<Markup(1))
What I want to display in the text box is
the value is <<a, but > b
Re: Using "<" and ">" as normal text when using Markup with a Text Box
Maybe escaping with "<" with &lt; could work?
string = "the value is <b> &lt;&lt;a </b>, but <i> > b </i>";
new window("test",
 And &gt; for >
new window("test",
 And &gt; for >
MathStatChem
That's it! I tried using &lt and &gt, but without the semicolon after.
