ac7872
Using expressions for theme format
I am trying to make the formatting of multiple similar plots into an expression so I can change a single section of the code to update all plots that look alike. However, I have a hard time implementing it into code. I am including a minimal working example showing how I would like a plot to look like and how I would like my code to look like, storing a piece of code for the formatting and a compact code for each plot. Any idea on how I can modify this to make it work? I am working on JMP version 15.2.
dt = New Table( "Minimal Working Example",
	Add Rows( 400 ),
	New Column( "X", Numeric, Set Values( Repeat( 1 :: 20, 20 ) ) ),
	New Column( "Y", Numeric, Set Values( Sort Ascending( Shape( Repeat( 1 :: 20, 20 ), 1 ) ) ) ),
	New Column( "Size", Numeric, <<Formula( Random Uniform( 0, 1 ) ) )
// How I would like the plot to look like
dt << Graph Builder(
	Variables( X( :X ), Y( :Y ), Color( :Size ) ),
	Elements( Points( X, Y, Legend( 8 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				8,
				Properties(
					0,
					{gradient( {Color Theme( "White to Red" )} )},
					Item ID( "Size", 1 )
		Dispatch(
			"400",
			LegendBox,
			{Legend Position( {8, [0, -1]} ), Position( {0, -1} )}
// A theme format I could change for a gazillion of plots
formats = Expr(
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				8,
				Properties(
					0,
		Dispatch(
			"400",
			LegendBox,
// How I would like each plot code to look like
	formats
ac7872
Re: Using expressions for theme format
That did not work very well because of the ways X, Y and Color variables change on my data, however I managed to find a closer solution to what I wanted using JSL Quote, Eval Insert, Parse, and Eval:
formats = JSL Quote(
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				8,
				Properties(
					0,
		Dispatch(
			"400",
			LegendBox,
Eval(Parse(Eval Insert("dt << Graph Builder(
	^formats^
Expression handling is powerful, and takes a bit of practice. Here is an example to get you started, but you'll want to read up on things like Eval(), Expr(), NameExpr(), Substitute(), Substitute Into(), etc.
//make a 5-column table
dt = astable((1::20)` || J(20,4,randominteger(0,20)));
//the x column will be the first column
xCol = column (dt, 1);
//the y columns will be the remaining columns
yColList = (dt << get column names())[2::ncol(dt)];
//write the graph builder script, wrapping it in an expression. Use _XXX_ format for things
//you'll be substituting later. Here, that is just the "y" variable for a particular graph.
gbExpr = expr(
		Variables( X( xcol ), Y( _Y_ ) ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					8,
					Properties(
						0,
			Dispatch(
				"400",
				LegendBox,
				{Legend Position( {8, [0, -1]} ), Legend Position( {0, -1} )}
//cycling through the items in yColList, we create a graph for each y variable vs the x variable.
//be sure to read up on Name Expr ( ), as it is needed here to prevent evaluation of the Graph
//Builder script... we just want the code itself... we don't want JMP to try to evaluate the code
//until after we've made the substitution.
for (i = 1,i <=nitems(ycolList), i++,
	eval(Substitute( nameExpr(gbExpr),  expr(_Y_) , expr(yColList[i])));
Cheers,
Brady
ac7872
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				8,
				Properties(
					0,
		Dispatch(
			"400",
			LegendBox,
	^formats^
