jcminor
Using an OR statement in selecting rows for exclusion
I am a JSL newbie ...
I want to select rows and then hide and exclude based on two criteria using an OR statement.  I want to select when 'comment' is blank or when Excluded Sum < 2.  I can get both conditions to work independently but when I combine them with an OR statement, no rows are selected.  I have also tried current selection ("extend") with the same result.  I am using JMP 15.2.0
dt =Current Data Table();
dt <<Clear Row States();
dt << select where(:comment == "" | :Excluded Sum < 2);
dt << invert row selection;
dt << exclude;
dt << hide;
Thank you for any thoughts on this.
Craige_Hales
Re: Using an OR statement in selecting rows for exclusion
I think rewriting the logic so the InvertRowSelection isn't needed might help make the intent clear. I'm guessing you might really mean something like this
dt << select where(
	:comment != "" // exclude if there is a comment
	| // or
	:Excluded Sum >= 2 // if there are too many excluded
//dt << invert row selection; // leave this out, it makes the logic hard to follow
dt << exclude;
dt << hide;
Craige
6 REPLIES 6
My test case works great, using your code.
dt = New Table( "Example",
	Add Rows( 10 ),
	New Column( "Comment",
		Character,
		"Nominal",
		Set Values(
			{"not blank", "not blank", "", "not blank", "", "not blank", "not blank",
			"", "not blank", "not blank"}
		Set Display Width( 89 )
	New Column( "Excluded Sum",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [5, 1, 51, 44, 6, 0, 7, 1.5, 9, -5] )
dt << Clear Row States();
dt << select where( :comment == "" | :Excluded Sum < 2 );
dt << exclude;
dt << hide;
jcminor
@txnelson I still can't get the script to work on my data set.  I've trimmed it down and attached it with the script to this post.  I'm afraid I'm missing something obvious here.  Thanks.
The data table you provided has no rows that do not meet the criteria for you Select Where.  Every row has either an Excluded value less than 2 or a Comment that is blank, or both.  Every row that has a Comment, has an Excluded Sum of 1, which is less than 2.  So given your code, no rows will end up hidden and excluded.
Craige_Hales
dt << select where(
	| // or
dt << exclude;
dt << hide;
Craige
jcminor
@Craige_Hales That works perfectly!  I need to brush up on my logic skills as well as learning JSL.  Thank you.
jcminor
@txnelsonI was afraid of that - it seems my logic is rusty.  Thanks.
