Using JMP to Connect to Spark Tables using Data Bricks/JDBC Driver
Using JMP to Connect to Spark Tables using Data Bricks thru JDBC Driver
I cannot find any documentation on how to do this... is this possible? how do I go about it?
Byron_JMP
Re: Using JMP to Connect to Spark Tables using Data Bricks/JDBC Driver
Maybe a good start is to install the Simba ODBC Driver, and then configure a DNS.
From there, try to use the ODBC Driver to make a connection to the data base in JMP.
https://www.jmp.com/support/help/en/15.1/index.shtml#page/jmp/connect-to-a-database.shtml
