cpark2
Using Column Switcher with Graphlets
I'm trying to make a series of drill down graphs with graphlets.  I'd like to have the column switcher available in each of the drill down graphs.  Is this possible?  When I try, the column switcher always goes away.
Re: Using Column Switcher with Graphlets
You can for example utilize Click
dt = Open("$SAMPLE_DATA/Big Class Families.jmp");
gb = dt << Graph Builder(
	Show Control Panel(0),
	Variables(X(:height), Y(:weight)),
	Elements(Points(X, Y, Legend(4)), Line Of Fit(X, Y, Legend(6))),
		Dispatch({}, "Graph Builder", FrameBox,
			{Set Graphlet(
				Picture(
					Distribution(
						Nominal Distribution(Column(:age)),
						Automatic Recalc(1)
				Click(
					dist = Distribution(
						Automatic Recalc(1)
					dist << Column Switcher(:age, {:name, :age, :sex});
