bhupi
Use first row as header row
Hi, I have just start using JMP Pro 11. Don't have any experience with JMP but a regular user for SAS. I do have data import question for JMP. I have JMP add-on in excel and using it to bring data into JMP. Once data come into JMP, I do transpose rows into column using "Transpose" option. However, I am unable to find how to convert first row into header row. Suggestions please.
Thanks, Bhupinder
bwanders
Re: Use first row as header row
Click on JMP in the Excel toolbar, then click on  "preferences".  You will see where to check the box for "Use first rows as column names"
bwanders
These are fixes in excel right.. How to fix this in jmp itself? To be specific, how to change my first row to headers row in jmp itself (I am using jmp 19 version)
Got the way. If you already have the data in jmp. Go to "Cols" < "Column Names" < "Move up"
