nathan-clark
Turning Private data tables on and off
In keeping many of my scripts clean, I use 'private' quite a lot. However, if I am troubleshooting a script, having tables as private gets in the way and I need to comment out and hopefully remember to uncomment as I make changes to see if the changes work.
Is there a way, or does JMP already have a global way to turn private tables on or off? In my head I could take the time to make duplicates of my code with and without the private and tie it to a test variable, but that doesn't seem like the best answer.
Wasn't sure if there were any ideas out there on how to do that. Thanks!
12 REPLIES 12
nathan-clark
Re: Turning Private data tables on and off
Yes! That's definitely on my radar. I have a library of functions/utilities I keep a lot of that stuff on hand (and distribute), and shifting to the custom function aspect is one plan long term for many of the more dynamic functions.
vince_faller
Nathan, is this helpful at all?
Names default to here( 1 );
dt = open("$SAMPLE_DATA\Big Class.jmp");
privateTable = Function({bool,dt},{default local},
	table_name = dt << Get Name;
	If(!bool & !(dt << HasDataView), // no table but you want one
		print("making "||table_name||" public");
		dt << New Data View;
		Return(dt);
	, // elif
		bool & dt << HasDataView, // you have a table but want it private
		print("making "||table_name||" private");
		dt_sub = dt << Subset( All rows, Selected columns only( 0 ), "private" );
		close(dt, no save);
		dt_sub << Set Name(table_name);
		return(dt_sub);
	, // else just return what's given
		print("passthrough");
		return(dt);
dt = privateTable(1, dt); // should make it private
wait(2);
dt = privateTable(1, dt); // should do nothing
wait(2);
dt = privateTable(0, dt); // should do make it visible
wait(2);
dt = privateTable(1, dt); // should do make it private again
Vince Faller - Predictum
nathan-clark
That's excellent, Vince! It's similar to what I ended up doing, but it's much more elegant in allowing the dataview to go both ways.
