Trying to JSL script and get the maximum desirability from RSM design
Hello!
New user of JMP. I'm using the student trial version, and I want to use the JSL script to use RSM design. Here's how far I got...
// Here are the factors and the ranges
factors = {
	{"X1", 0, 1, "Continuous"},
	{"X2", 0, 1, "Continuous"},
	{"X3", 0, 1, "Continuous"}
rsm = DOE( Response Surface Design );
// Add a response
rsm << AddResponse( Minimize, "Y");
// Add the factors. We will need to overwrite the defaults
// overwrite the two built‑ins
For( i = 1, i <= Min( N Items( factors ), 2 ), i++,
	rsm << Change Factor Settings( i, factors[i][2], factors[i][3], factors[i][1] );
// add any remaining
For( i = 3, i <= N Items( factors ), i++,
	rsm << Add Factor( Continuous, factors[i][2], factors[i][3], factors[i][1], 0 );
rsm << Set Random Seed( 30624700 );
rsm << Make Design( 2 );
rsm << Set Axial Choice( 4 );
rsm << Center Points( 0 );
rsm << Make Table;
dt = Current Data Table();
// Set the response here
yvals = { 1.23, 0.98, 1.05, 0.76, 1.12, 1.23, 0.98, 1.05, 0.76, 1.12, 1.23, 0.98, 1.05, 0.76};
dt:Y << Set Values( yvals );
/////// Fit the RSM ///////
// Fit the RSM
fm = dt << Fit Model;
fls = fm <<  Run;
I got as far as getting the data table with the factors and inserting some dummy yvals. I can fit the quadratic model, and run that. It seems that I get some sort of a report object, but I want to use the "Prediction Profiler", "Maximize desirability", and "Remember" the optimal. I want to add those suggested optimal factors into the data table. These keywords are all found in the Scripting Index, but I cannot figure out how to make this work in JSL.
Any help would be super appreciated! Thank you so much.
Re: Trying to JSL script and get the maximum desirability from RSM design
I think you have to find a reference to the profiler platform. You can do it by finding reference to the Prediction Profiler outline box and then using << Get Scriptable Object
profiler_ob = (Report(fls) << XPath("//OutlineBox[@helpKey='Profiler']"))[1];
pf = profiler_ob << Get Scriptable Object;
You should also be able to get the reference via report subscripting
profiler_ob = Report(fls)[OutlineBox("Prediction Profiler")];
After that you can use pf as you would Profiler object, for example
pf << Maximize Desirability;
Amazing! Thank you
