UserID16644
Transpose non specific data columns
Hi all,
I am creating a script in jsl but I am having a problem in transposing the table since the columns needed needs to be specified. However, in my case, the columns depend on the data, so it is changing.
How can I create a jsl script where I can transpose non specific data columns?
Re: Transpose non specific data columns
When you know the names of columns you wish to transpose, you can use them in Transpose(columns()) using eval
cols_to_transpose = {"height", "weight"};
dt_transposed = dt << Transpose(
	columns(Eval(cols_to_transpose)),
	Label column name("name"),
	Output Table("Transpose of Big Class")
Here is one example of a Transpose script that  examines the data from the data table and generates a transposed data table based upon the data;
theTranspose = Expr(
// Get the first character column to use as the Label
	theLabel = (dt << get column names( string, character ))[1];
// Get the numeric columns.  All numeric columns will be transposed
	theTransColumns = dt << get column names( string, numeric );
// Transpose the data
	dt << Transpose( columns( theTransColumns ), Label( As Column( theLabel ) ) );
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
theTranspose;
// Open Data Table: Blood Pressure.jmp
// → Data Table( "Blood Pressure" )
Open( "$SAMPLE_DATA/Cities.jmp" );
theTranspose;
I am sure this does not solve your specific problem, however, not knowing what your rules for how you want to transpose were not specified, I set the rules to be that all numeric columns found will be transposed, and that the first character column found would contain the new column names.
