Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
You might get a lot of answers of ways to do this with existing tools in JMP but I still use the script below which is ran from a menu item inside a table. Select columns in a table, run the script, write a formula referencing those first columns, and then every selected column is transformed.
Names default to here( 1 );
//Reference current table
dt1 = Current Data Table();
//flag to output a bunch of status info to the log file
debug = 0;
//window box, all code is inside this box
nw = New Window( "Custom Column Transformation",
//box to hold spacers on left and right side of data
H List Box (
//spacer on left side of window
Spacer Box( Size( 12, 12) ),
//box to hold all other parts of window
V List Box(
//heading and instructions
Text Box( "Choose Transformation Settings " ),
Spacer Box( Size( 12, 12 ) ),
V List Box( Text Box( "Directions:" ||
"\!N1. Select columns to transform in the data table." ||
"\!N2. Type a formula below, or select an example." ||
"\!N3. Select a phrase to be appended to each new column name." ||
"\!N4. Press OK." ||
"\!N5. Repeat 2-4 as necessary." ||
"\!N6. Press Close/Cancel to exit."),
Spacer Box( Size( 12, 12 ) ) ),
//radio buttons with examples, when selected the text in the formula edit box is modified
panelbox("Example Equations",
rb1 = radio box({"Lag", "Change", "Shuffle", "Date Dep", "Column Only", "Cos Oscillation", "Sin Oscillation", "10 day t score"},
one_rb = rb1 << get selected;
if (one_rb == "Lag",
FormulaIn << set text("Lag(<column>,1)");,
one_rb == "Change",
FormulaIn << set text("<column> - Lag(<column>,1)");,
one_rb == "Shuffle",
FormulaIn << set text("Col Stored Value(<column>, Col Shuffle())");,
one_rb == "Date Dep",
FormulaIn << set text("If( As Column( \!"Date\!" ) < Date DMY( 1, 1, 2016 )," ||
"\!N\!t<column> / 10,\!N\!t<column>\!N)");,
one_rb == "Cos Oscillation",
FormulaIn << set text("cos(<column> * (2 * pi()) / Col Max( <column> ) )");,
one_rb == "Sin Oscillation",
FormulaIn << set text("sin(<column> * (2 * pi()) / Col Max( <column> ) )");,
one_rb == "10 day t score",
(<column> - Mean(
Lag( <column>, 1 ),
Lag( <column>, 2 ),
Lag( <column>, 3 ),
Lag( <column>, 4 ),
Lag( <column>, 5 ),
Lag( <column>, 6 ),
Lag( <column>, 7 ),
Lag( <column>, 8 ),
Lag( <column>, 9 ),
Lag( <column>, 10 )
) ) / Std Dev(
Lag( <column>, 1 ),
Lag( <column>, 2 ),
Lag( <column>, 3 ),
Lag( <column>, 4 ),
Lag( <column>, 5 ),
Lag( <column>, 6 ),
Lag( <column>, 7 ),
Lag( <column>, 8 ),
Lag( <column>, 9 ),
Lag( <column>, 10 )
FormulaIn << set text("<column>");
//Formula edit box with instructions
Spacer Box( Size( 6, 6 ) ),
V List Box( Text Box( "FORMULA\!NCreate a new column in the data table and then copy/paste the formula from " ||
"the formula editor. Then use <column> up to 50 times to indicate where column names " ||
"should be substituted. Reference other columns using As Column(\!"Column Name\!")." ),
V List Box(
FormulaIn = Text Edit Box(
"Lag(<column>,1)",
<<Justify Text( Left ),
<<Set Width( 400 ),
<<setNlines( 5 )
//Description edit box with instructions
V List Box ( Text Box( "DESCRIPTION\!NText appended to each new column name:" ) ),
V List Box ( DescIn = Text Edit Box( " TRANSFORMED",
<<Set Width( 400 ),
<<setNlines( 1 )
Spacer Box( Size( 25, 25 ) ),
//Box to hold command buttons
H List Box(
//Button to create new columns
Button Box( "OK",
//get list of colums selected in the data table
ColumnList = dt1 << Get Selected Columns();
//TODO: loop through this section for multiple input columns, list of <column1>, <column2>, etc.
//variable to hold text string to be replaced with column names
ReplaceTarget = "<column>";
//Get formula from text box
FormulaInput = FormulaIn << Get Text;
//get column description from text box
DescInput = DescIn << Get Text;
//output debug info
if (debug == 1,Show( FormulaInput );Show( DescInput );Show( ColumnList ););
//get number of selected columns
n = N Items( ColumnList );
//for each column
For( i = 1, i <= n, i++,
//get data type of column
ColumnDataType = Column( ColumnList[i] ) << Get Data Type;
//output debug info
if (debug == 1,Show( columnList[i] );Show( ColumnDataType ););
//create new variable for modified formula
FormulaComplete = FormulaInput;
//TODO: stop itterating when string no longer found or after a huge number of cycles
//replace column reference for up to 50 occurances (change this for large formulas)
For( j = 1, j <= 50, j++,
//output debug info
if (debug == 1,Show( FormulaComplete );Show( Contains( FormulaComplete, ReplaceTarget ) );
Show( Length( ReplaceTarget ) ););
//if the formula contains the target string
If( Contains( FormulaComplete, ReplaceTarget ) > 0,
//replace the first occurance of the target string
FormulaComplete = Eval(
Munger(
FormulaComplete,
Contains( FormulaComplete, ReplaceTarget ),
Length( ReplaceTarget ),
"As Column(\!"" || Char( ColumnList[i] ) || "\!")"
); //end if formula contains reference string
); //loop for each occurance of the reference string
//output debug info
if (debug == 1,Show( FormulaComplete ););
//create string containing expression that will create the new column reference
newColExpr = Expr(
dt1 << New Column( Char( ColumnList[i] ) || Char( DescInput ),
Expr( ColumnDataType ),
Formula( Eval( Parse( FormulaComplete ) ) )
//output debug info
if (debug == 1,Show( Eval Expr( newColExpr ) ););
//Try creating the new column reference
Try( Eval( Eval Expr( newColExpr ) ) );
//TODO: Check if new column was created and it has a formula, inform user
//output debug info
if( debug == 1, Show( "done" ););
); //loop each selected column
), //end of 'OK' command button
//button to close the window
Button Box( "Close/Cancel",
Show( "Closed" );
nw << Close Window;
), //end of box to hold command buttons
//spacer on bottom of window
), //end of vertical box with all window content except left and right spacers
//spacer in right side of window
) //end of horizontal box for spacers on left and right side
); //end of window box
If you have something simpler for what I described above that I can embed in other scripts, that will be useful for list of column names that I have generated in other parts of my script. If not, I can parse and use parts/concepts in your code to do that.
