Lirsch
Transfer data from/ Excel/VBA to JMP and get data back to VBA
Hi, I'd like to describe what I need in order to have some kind of automation I'm planning.
I have a report I've already generated using Excel/VBA and I'm missing a distribution graph from JMP which is currently being made manually
And added to the report.
I'd like to know how can I send the data from Excel to JMP, generate the distribution graph and save it back to my excel sheet.
To be specific, let's say I have the data for the dist. graph on my "rawData" sheet at range(A1:A1000) in excel and would like to save the dist. graph from JMP to the "DistGraph" sheet.
Thanks in advance,
Liron.
ian_jmp
Level X
Re: Transfer data from/ Excel/VBA to JMP and get data back to VBA
If you are already familiar with OLE and VBA, then the JMP Automation Reference should get you started.
