cjw99
Time-dependent cox model
I have been a loyal JMP user for more than ten years, and I have introduced many of my colleagues and students to JMP. I love its user interface and the speed with which I can do analysis.
However, more and more clinical journals in my field (transplantation) require time-dependent models (usually Cox models) for publication (see Gaynor et al. Am J Transplant. 2023 p.815 recently highlighting this in the number one transplant journal in the world). Thus, as a clinician, I am increasingly forced to rely on my statistical colleagues using R to help me conduct this analysis since JMP lacks this ability.
This is extremely frustrating since I can perform all other univariable and multivariate analyses myself, but as soon as I hit this roadblock, it slows down my workflow because I now have to depend on others to do my analysis.
Although I would love to keep using JMP, at this point, it is becoming harder and harder not to bite the bullet and learn how to use R (I really don’t want to spend the time learning how to code).
Can you tell me if JMP ever plans to support time-dependent Cox models?
Thierry_S
Re: Time-dependent cox model
I might be naive, but would the Proportional Hazard analysis in the Survival and Reliability platform meet your requirements?
https://www.jmp.com/support/help/en/17.2/?os=win&source=application#page/jmp/fit-proportional-hazard...
Best regards,
TS
Thierry R. Sornasse
You can use R with JMP. Your colleagues could write the R script for you. You will need a little JMP script to run it. You can send data and variables to R and return results from R for further analysis and display in JMP.
