Technical Consultation
Optimisation of Formulations1.1 Intelligent algorithm support, calculating the optimal blending ratios of various batches of powder based on target performance ranges (for example, "tensile strength must be stable at 120±5MPa").1.2 Multi-index balancing: Supports simultaneous optimisation of 3-5 key performance parameters, automatically avoiding conflicts between indicators.1.3 Constraint setting: Allows setting of raw material inventory priorities, special batch disabling rules, and other business logic.
Joyce_Pan
Re: Technical Consultation
To find the optimal blending ratios, please refer to the attached files.
The control charts and process capabilities show that there is large variability in test properties before blending, so I really reccommend you launch a project to lower the variability systematically. Then you are able to mix different batches with more flexibility and make sure they always meet the spec limits.
Best regards,
Joyce
