Created:
Feb 23, 2022 03:18 PM
| Last Modified: Feb 23, 2022 12:19 PM(3401 views)
| Posted in reply to message from mikesh 02-23-2022
The complete list of escape sequences available are found on page 102 in the Scripting Guide, available in the JMP Documentation Library found under the Help pull down menu.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '463434' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '463434') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '463434') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
