Dear JMP Community,
I'm interested in scripting a small window that pops up when I run my model building script to show me at which step (out of thousands) is it currently running. I'm thinking of doing something like the following script, which works, but also makes a new window each time.
imax = 5;
For( i = 1, i <= imax, i++,
update_window = New Window( "Progress Update",
Text Box( " Current step " || Char( i ) || " of " || Char( imax ), <<Set Font Size( 12 ), <<Justify Text( "center" ), <<Set width ( 250 ) ),
Of course, my imax is much larger than 5, this is just a test script. I get an output at each iteration of the following (five windows in this case):
But, as mentioned, this would make several thousand such windows, which I don't want. I'd like to update just the step "i" of the total.
The modeling script is built into a data table and has it's own FOR loop as it's running a giant tuning table one line at a time -- imax is the NRows() of this tuning table, and can be on the order of 24k+ rows. I want to insert into the main for loop a script that creates a single window that stays on the screen and tells the user what step "i" it's at out of NRows(). (Scrolling through the data table is tedious, and this seems like a reasonable solution.)
I don't need a progress bar, or anything like that, just a simple number that changes at each iteration of the main FOR loop. There is only one FOR loop, BTW.
Thanks for your suggestions!
DS
