Stability studies
Hi, Asking for ideas for analyzing data from a stability study with multiple compounds changing over time at different rates with many different types of samples included in the study.  Each data point is from a separate sample that has been aged for a given point in time.  Suggestions would be appreciated.
David_Burnham
Re: Stability studies
I model stability of pharmaceutical products over time, based on conditions such as temperature and humidity (solids), or temperature and pH (liquids).  To do this I use the nonlinear platform (Analyze>Specialized Modeling>Nonlinear).
This approach does require that you know the functional form of the model.  This comes from domain knowledge and some understanding of  the mechanisms for degradation.  I use various modified forms of the Arrhenius equation (that are illustrated in the talk in the link below).
If you do a search, not just for 'this board' but across the entire community you will find a number of interesting presentations from past Discovery summits.
Here is one that I was involved with (it's custom code but behind the scenes it is the nonlinear platform):
https://community.jmp.com/t5/Discovery-Summit-Europe-2022/Predicting-Molecule-Stability-in-Biopharma...
-Dave
David_Burnham
-Dave
Michelle_Ricci
