matt7109
Sort a column by variable
How would I go about creating a new column that contains the sorted values of one column by another variabe?
An example to hopefully clarify: if I had a table with two rows: Name and age, how would I create a third row that displays the names sorted from oldest to youngest?
Thanks!
Jeff_Perkinson
Re: Sort a column by variable
What you've asked for is not easily done in a formula (that I can come up with anyway). It's relatively easy to do this interactively by using Tables->Sort to sort the table into a new table and then copy and paste the column of interest back into the original table.
However the question raises some interest about what you're really trying to do.
Generally speaking, a row of a data table represents a collection of values for a single entity – an individual student in your simple example – and each row is unrelated to other rows. I'm not sure how this new column – of Names in your example – would be useful in an analysis since the new column is only meaningful in the context of it's order.
Can you explain a little bit more of how you'd use this new column?
PS: you seem to have confused rows and columns in your example. I'm assuming that you really meant a table with two columns and that you wanted to create a third column as your original question states. If I'm mistaken and you really meant rows, please let us know.
-Jeff
Jeff_Perkinson
-Jeff
IcarusAgenda
If you have your data in rows instead of columns, like in Excel, you'd need to transpose the table before analyzing it. In your example, after transpose, you will have two columns: Name and age. At this point, it simply becomes a matter of sorting the table by the age column, as suggested by other users.
ih
Super User (Alumni) ih
Give this a try:
names default to here(1);
dt << New Column(
	"Sorted names by age",
	Expression,
	"None",
	Formula( :Name[ Rank( :age << Get Values )][ Row() ] )
dt << New Column(
	"Sorted names by height",
	Expression,
	"None",
	Formula( :Name[ Rank( :height << Get Values )][ Row() ] )
Note that it might be slow for large tables.
Edited to show a more relevent example.
