MarkovVaribles1
Simulation for time to event data
I have failure data on some devices. Of the 15000, 45 have failed and the rest are censored at cycle 3000. Using the "Life Distribution" platform I fit a model and can estimate DPPM at various cycles.
I would like to randomly select 1/5 of the failed ones and and repeat the analysis and do this, say 100 times, and then get a histogram of the estimated dppm at a particular cycle.
Is there an add-in JMP tool to do this in JMP? This add-in will be useful for other analysis.
Thanks,
Re: Simulation for time to event data
Please see if the built-in Simulate or Bootstrapping feature will work for your purpose.
