JMPer1
Show only one graph out of a matrix of graphs
When there is a matrix of graphs, say 4x5 of them on the dashboard, how do I pick just one graph of all and show it zoomed in? The selection does happen when a data filter is used when the two columns from the data table used to form the graphs in the horizontal and vertical direction and are narrowed down to a desired pair. It would be useful to have a single zoomed in graph where this selection is made from a drop down lists instead of histogram like control on the data filter form.
Re: Show only one graph out of a matrix of graphs
If you have a single graph builder with x and y groups and filter
just by filtering down the data you should get single graph
You can change how filter looks from filter's red triangle menu
hogi
Level XIII
For solving the first problem:
If you filter your data just keeping e.g. a graph with GroupX=1, GroupY=1 and another graph with GroupX=2,GroupY=2, you will indeed still see a 2x2 matrix of graphs with x=1,2  , x=1,2 with just position 1/1 and 2/2 containing a graph and the other 2 positions empty.
If you don't care where the individual plots show up, then you could remove the white regions by
- combining the columns used for GroupX and GroupY to a single column (get still the required intersections)
- use this column as Wrap
On the other hand, this example also shows the disadvantage:
you lose the information about the specific X and Y value.
From daily work in Data Visualization, I know:
There are definitely cases where the benefit of the denser packing overweights the disadvantage of the lost structure :)
Especially when the generated Matrix has to fit into a Powerpoint slide ...
related topic: X group: restrict the values on the axis to the respective group
Names Default to Here(1);
Graph Builder(
	Variables(
		X( :height ),
		Y( :weight ),
		Group X( :age ),
		Group Y( :sex ),
		Overlay( :sex )
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :age, :sex ),
			Where( :age == 12 ),
			Where( :sex == "F" )
		Add Filter(
			Where( :age == 15 ),
			Where( :sex == "M" )
				Add Filter(
			Where( :age == 17 ),
New Column( "Concatenate[age,sex]",
	Character,
	Formula( Char( :age ) || "_" || :sex ),
Graph Builder(
	Variables(
		X( :height ),
		Y( :weight ),
		Group X( :"Concatenate[age,sex]"n ),
		Overlay( :sex )
	Local Data Filter(
		Add Filter(
			columns( :"Concatenate[age,sex]"n ),
			Where( :"Concatenate[age,sex]"n == {"12_F", "15_M", "17_F"} )
JMPer1
I am missing the "Display Options" item on the menu, not sure where to find it?
