BabyDoragon
Sharing a Local Data Filter between Graph Builders for synchronized data display
I would like to share the same Local Data Filter between two Graph Builders. For example, when selecting F, both Graph Builders should only display data related to F; and, when selecting M, both Graph Builders should only display data related to M.
How can I achieve this?
New Window( "Weight VS Height",
	outlineBoxA = Outline Box( "Weight VS Height",
		Graph Builder(
			Size( 528, 456 ),
			Show Control Panel( 0 ),
			Variables( X( :weight ), Y( :height ) ),
			Elements( Points( X, Y, Legend( 7 ) ) ),
			Local Data Filter( Add Filter( columns( :sex ), Where( :sex == "M" ) ) )
		Graph Builder(
			Size( 534, 450 ),
			Variables( X( :age ), Y( :weight ) ),
Re: Sharing a Local Data Filter between Graph Builders for synchronized data display
You can use data filter context box
nw = New Window("Weight VS Height",
	Data Filter Context Box(
		outlineBoxA = Outline Box("Weight VS Height",
			H List Box(
				Data Filter Source Box(
					dt << Data Filter(
						Local,
						Add Filter(columns(:sex), Where(:sex == "M"))
				V List Box(
					dt << Graph Builder(
						Size(528, 456),
						Show Control Panel(0),
						Variables(X(:weight), Y(:height)),
						Elements(Points(X, Y, Legend(7)))
						Size(534, 450),
						Variables(X(:age), Y(:weight)),
Write();
Construct Display Boxes for New Windows (jmp.com)
			H List Box(
					dt << Data Filter(
						Local,
				V List Box(
						Size(528, 456),
						Size(534, 450),
Write();
