miguello
Setting values to a cell
Hello all,
It's been some time since I did any programming in JSL, so I'll be asking some basics questions which I did not find in the manuals.
1. How, using a JSL, I can set a specific value to a specific Col/Row?
2. I need to do that in a For loop. Let's say I need to run a loop from 1 to number of rows, and assign (for now) the same number to each Row of a Specific column. How do I do that this way?
3. Specific example. I have M sets of N measurements. I have datetime for each measurement. I know that each mth measurement was done in order. But do not have column that says what set it is, I only have column that has the measurement.
In other words I have only first column, and I need to make the second.
I know how to do the logic - See the difference between current row and the previous one, and as soon as it's not 1, iterate the MeasSet counter.
But how do I iterate and how do I write this FOR loop?
I wrote it once, but lost the code and starting from the beginning here.
Counter1MeasSet
1
1
21
31
41
51
12
22
32
42
52
ms
Super User (Alumni) ms
Re: Setting values to a cell
Here are some examples that may give you an idea:
dt = Current Data Table();
// 1. With a column variable
col = Column(dt, "MeasSet");
col[6] = 2;
// or directly
// "dt" in Column() is optional but good if same column name occurs in other open tables
Column(dt, "MeasSet")[1] = 1;
// 2.
For Each Row(col[] = 1);
// 3.
For(i = 1, i <= N Rows(dt), i++,
    If(:Counter1[i] == 1,
        col[i] = set = 1,
        col[i] = set
    set++;
ms
col[6] = 2;
// or directly
// 2.
// 3.
        col[i] = set = 1,
        col[i] = set
    set++;
miguello
Thanks,
I came up with this solution:
i=1;
For Each Row(
If ((:Counter1 - lag(:Counter1))!=1, (i++; :MeasSet=i) , (i=i; :MeasSet=i), (:MeasSet=i) );
I need to stress two things:
1. Needs to be !=, not ==
2. Had to put i=i, otherwise script asks if I want to use comparison "==" or assign value "=" for next MeasSet.
