scott1588
Setting Values in a Column with Choose
I'm having what I'm sure is a simple issue with setting values in a column using the Choose function. Below is a test script along with a table showing desired output.
startTime = 3742070400;
endTime = 3742074000;
dt = New Table( "Test",
	Add Rows( 60 ),
	New Column( "Timestamp", Format( "m/d/y h:m", 19 ), Set Display Width( 175 ) )
For Each Row( :Timestamp[] = Sequence( startTime, endTime, 60 ) );
aggOption = 1; // This will eventually be a pulldown menu with choices
New Column( "Agg Minute",
	Numeric,
	"Ordinal",
	Format( "Best", 12 ),
	Set Display Width( 116 )
// Script below is the problem. I tried For Each Row and Set Values and a combination
// of both but the column always is blank. See Interpolated Data table for what it
// should look like.
dt:"Agg Minute"n << For Each Row(
	Choose( aggOption,
		If(
			Minute( :Timestamp ) < 15, 15,
			Minute( :Timestamp ) < 30, 30,
			Minute( :Timestamp ) < 45, 45,
			0
		If(
			Minute( :Timestamp ) < 14, 0,
			Minute( :Timestamp ) < 29, 15,
			Minute( :Timestamp ) < 44, 30,
			45
		If(
			0 < Minute( :Timestamp ) <= 15, 15,
			15 < Minute( :Timestamp ) <= 30, 30,
			30 < Minute( :Timestamp ) <= 45, 45,
			0
Notice when you run the script the Agg Minute column is blank. I've tried Set Values and For Each Row and a combination of both but I can't seem to get it to work.
As always, any assistance is greatly appreciated.
Thanks.
Re: Setting Values in a Column with Choose
You are using For Each Row incorrectly. You don't send it to a column, it is a function you provide with (optional) data table and body argument and within body you can set values to columns.
Here is fixed version
dt = New Table("Test",
	Add Rows(60),
	New Column("Timestamp", Format("m/d/y h:m", 19), Set Display Width(175))
For Each Row(:Timestamp[] = Sequence(startTime, endTime, 60));
aggOption = 1;
New Column("Agg Minute", Numeric, "Ordinal", Format("Best", 12), Set Display Width(116));
For Each Row(dt,
	:"Agg Minute"n = Choose(aggOption,
		If(
			Minute(:Timestamp) < 15, 15,
			Minute(:Timestamp) < 30, 30,
			Minute(:Timestamp) < 45, 45,
			0
		If(
			Minute(:Timestamp) < 14, 0,
			Minute(:Timestamp) < 29, 15,
			Minute(:Timestamp) < 44, 30,
			45
		If(
			0 < Minute(:Timestamp) <= 15, 15,
			15 < Minute(:Timestamp) <= 30, 30,
			30 < Minute(:Timestamp) <= 45, 45,
			0
scott1588
I can get it to work as a column formula if I set a local variable. But then I can't use my combo box result.
Here is that code. There is obviously much more I need to learn about JSL. It is very easy to auto-generate code. But often when I try to customize it, it breaks and I don't know enough yet to fix it.
Arrgh.
	Numeric,
	"Ordinal",
	Set Display Width( 116 ),
	Formula(
		Local( {aggOption = 1},
			Choose( aggOption,
				If(
					0
				If(
					Minute( :Timestamp ) < 15, 0,
					Minute( :Timestamp ) < 30, 15,
					Minute( :Timestamp ) < 45, 30,
					45
				If(
					0
	Add Rows(60),
aggOption = 1;
For Each Row(dt,
		If(
			0
		If(
			45
		If(
			0
scott1588
Thanks much, Jarmo. It worked like a charm.
