afterword
Setting Initial Value in Modal Combo Box
I'm trying to request start and end dates from the user through a modal dialogue using the combo box. I'd like 2009 to be selected in the year field by default, but I can't figure out how to accomplish this with the following year list:
years = {"2006", "2007", "2008", "2009"};
When I use
startYear = comboBox(years, <the script is ignored, though this format is interpreted properly in the non-modal framework.
Any ideas for setting a default in the modal dialogue?
SDF1
Re: Setting Initial Value in Modal Combo Box
Hi @afterword ,
  I came across this post searching for something similar. If you haven't yet found a solution, try using the <<Set() command where you'd enter the item number for the combo box. In your case, you'd enter 4 because this corresponds to "2009".
Hope this helps,
DS
Try this
New Window( "test",
	modal,
	startYear = Combo Box( years,x=years[startyear<<get] ),
	startYear << set( 3 )
After exiting the window, the variable "x" will contain the selected year.
