    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
DSA
DSA
Set column name with a string JSL
Hey everyone, i have a simple problem that i am struggeling with.
I've looked in various discussions but i cannot get it to work.
I have a string with column names which i am loading from a separate file, and i want use that string as a column in the control chart builder like this:
string="Concentration (‰)";
Control Chart Builder(
	Size( 480, 350 ),
	Show Two Shewhart Charts( 0 ),
	Show Control Panel( 0 ),
	Show Capability( 0 ),
	Variables(
		Subgroup( :RowNumber ),
		Subgroup( :BatchID, Position( 1 ) ),
		Y(:name(string)) // SET THE STRING IN HERE
	Chart( Points( Statistic( "Individual" ) ), Limits( Sigma( Levey Jennings ) ) )
How do i get the Y variaible to accept the string as a column name?
Thanks in advance,
Daniel
ih
Super User (Alumni) ih
Re: Set column name with a string JSL
You can use the Column() function. See the link below.
http://www.jmp.com/support/help/Columns.shtml
ih
DSA
DSA
Thanks for the help both of you.
It was as easy as:
Y(column(string))
I thought i've tried it, but it turned out that i called "columns" instead of "column", so it was a very easy fix.
Thanks for the quick and accurate help!
Daniel
markschahl
I had a similar question. The script is similar. See this post:
https://community.jmp.com/t5/Discussions/How-to-rename-columns-using-a-second-data-table/td-p/41065
I saw that you have units in the column name. Do you know about the Units column property?
