- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Set column name with a string JSL
Hey everyone, i have a simple problem that i am struggeling with.
I've looked in various discussions but i cannot get it to work.
I have a string with column names which i am loading from a separate file, and i want use that string as a column in the control chart builder like this:
string="Concentration (‰)"; Control Chart Builder( Size( 480, 350 ), Show Two Shewhart Charts( 0 ), Show Control Panel( 0 ), Show Capability( 0 ), Variables( Subgroup( :RowNumber ), Subgroup( :BatchID, Position( 1 ) ), Y(:name(string)) // SET THE STRING IN HERE ), Chart( Points( Statistic( "Individual" ) ), Limits( Sigma( Levey Jennings ) ) ) );
How do i get the Y variaible to accept the string as a column name?
Thanks in advance,
Daniel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Set column name with a string JSL
You can use the Column() function. See the link below.
http://www.jmp.com/support/help/Columns.shtml
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thanks for the help both of you.
It was as easy as:
Y(column(string))
I thought i've tried it, but it turned out that i called "columns" instead of "column", so it was a very easy fix.
Thanks for the quick and accurate help!
Daniel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
I had a similar question. The script is similar. See this post:
https://community.jmp.com/t5/Discussions/How-to-rename-columns-using-a-second-data-table/td-p/41065
I saw that you have units in the column name. Do you know about the Units column property?
