I do not have JMP version 5. I can't remember the menus or launch dialogs, which have changed much in the next 12 versions. Open your data table. Then select either Analyze or Graph menu and look for Control Charts. I think there is a sub-menu for the different types of charts. Select XmR or Individuals and Moving Range. The dialog should look something like this one:
Notice the number edit box in the lower left corner where you can change the default value of 3 for K Sigma.
Hello Jean, Just curious: Why would you want, or feel justified, to build a control chart with limits based on a multiple of 4.5 or 5 for the sigma value? Thanks, scott.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '618551' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '618551') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '618551') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
