robot
Set Column Values
I am creating several data tables, where I will add a Character column with repeating values.  I am using the repeat function to do this.  My trouble is that it seems to take a very long time for large repeat values.  Is there a more efficient way to do this?  I am using JMP11.  Thanks!
// Example.
t1 = Tick Seconds();
dt = New Table( "50000 Rows", Add Rows( 50000 ),
      New Column( "Hello!", Character, Nominal, Set Values( Repeat( {"Hi!"}, 50000 ) ) )
t2 = Tick Seconds();
Print( Concat( Char( t2 - t1 ), " seconds." ) );
ms
Super User (Alumni) ms
Re: Set Column Values
Set Each Value() should be a little more efficient:
New Column( "Hello!", Character, Nominal, Set each value("Hi!") )
ms
robot
Thanks MS!
