nikles
Send commands to multiple Bivariate Plots
I have a script that generates a series of bivariate plots within a single window, using a LineUpBox to contain each plot.  After the plots have been created, I want the option for the user to toggle on/off the points of the plot (I intend to add other options...this is serving only as one example).  I envision a buttonbox or checkbox in the window the user can click on, and all the plots will reflect this action.
For a single plot, I would use the command:
bvp << Show Points(0/1);
where bvp is the reference to the bivariate plot.  However, here I have multiple plots and cannot use a single reference for them all.  I tried referencing to my LineUpBox that contains the plots instead:
For(plid = 1, plid <= nplots, plid++,
 LUB_plots[plid] << Show Points(pts)
where LUB_plots is the reference to my lineupbox.   This loop would be run each time the user checks the checkbox, for example.  When I do this, I get the following errors:
The display box 'OutlineBox' does not recognize the message 'Show Points'; perhaps you mean one of these:  <<Show Properties <<Show HelpKeys <<SetHorizontal <<Horizontal <<SetOpen <<GetHorizontal <<Close Where No Outlines <<Font <<Set Font <<Set Font Style <<Set Font Size <<Reshow <<Set Report Title <<Set Window Title <<Top Parent <<Show Tree Structure <<Restore Window Size <<Set Window Size <<Set Content Size <<Get Window Position <<Show Window <<Get Show Window <<Set Window Title <<Set Window Icon <<Set Print Headers <<Set Print Footers <<Scroll Window <<Set Width <<Set Height <<Horizontal Alignment.
and an instance of the following for each plot:
(The following message might not be an actual error; the preference 'Report Invalid Display Box Messages' is ON.) The display box 'OutlineBox' does not recognize the message 'Show Points'.
I checked the tree structure and confirm that yes, the top display box is indeed an outline box.  So at least I know LineUpBox[plid] is aiming where I expected it to.  The problem seems to be that my <<Show Points command sees the outline box it's pointed to, but fails to recognize that the outline box is actually part of a bivariate plot.
My question: How can I reference multiple bivariate plots?  Alternatively, is there a better way to send commands to multiple bivariate plots after they've been created?  Perhaps using some sort of Dispatch/SendtoReports command structure?
Not sure how to even search the community for this one.  Any help is appreciated.
ms
Super User (Alumni) ms
Re: Send commands to multiple Bivariate Plots
Or much simpler with xpath, inspired by a JMP Summit presentation that just was posted here:
//Example report
Open("$SAMPLE_DATA/Big Class.jmp");
nw = New Window("example",
    lub = Lineup Box(
        Bivariate(Y(:weight), X(:height), FitLine()),
        Bivariate(Y(:weight), X(:age), FitLine()),
        Bivariate(Y(:age), X(:age), FitLine()),
        Bivariate(Y(:weight), X(:weight), FitLine())
//Make list of plots
L = (lub << xpath("//LineUpBox/OutlineBox")) << get scriptable object;
// Send messages to all plots, e.g
L << show points(0);
ms
The show points() message needs to be sent to the Bivariate object rather than to its top display box. From an existing display tree, a reference to the associated object can be obtained by <<Get Scriptable Object.
An example that also illustrates one way to send messages to multiple plots:
//Example report
    lub = Lineup Box(
//Make list of plots (here top-level Outline boxes)
L = {};
i = 1;
While(Is Scriptable(Try(lub[Outline Box(i)])),
    If((lub[Outline Box(i)] << parent) << classname == "LineUpBox",
        Insert Into(L, lub[Outline Box(i)] << get scriptable object)
    i++;
ms
//Example report
    lub = Lineup Box(
nikles
Thanks!  The xpath cmd works great for my show points example.
Now I have a followup.  How can I send a command to all my plots that changes the y-axis from linear to log?  As a start, I tried using the xpath command with the intent of creating a list of all references to all the y-axis boxes. I'm first just trying to confirm that the xpath command is pulling the correct refs.  But I can't seem to get it to return just those boxes though.  By inspecting the xml code in the log, I could see the y-axis boxes all have a "charID=\!"2\!"", so I'm trying to use that to differentiate the y's from the x's, but no luck.
//Example report
Try(Window("example") << Close Window);
    lub = Lineup Box(
Show(lub << Get xml); Show(lub << xpath("//AxisBox")); //list of 8 displayboxes Show(lub << xpath("//AxisBox[2]")); //empty list Show(lub << xpath("//AxisBox['2']")); //list of 8 displayboxes Show(lub << xpath("//AxisBox[\!"2\!"]")); //list of 8 displayboxes Show(lub << xpath("//AxisBox[charID=\!"2\!"]")); //empty list Show(lub << xpath("//AxisBox[\!"charID=2\!"]")); //list of 8 displayboxes
How can I get xpath to return just the 4 y axisboxes?
Once I succeed in generating the references to the specific axis boxes I want, do I need to send the "Get Scriptable Object" command as with your previous example, or can I just send the "Scale" command directly to the list of references?
I read through the JMP Summit presentation and the .jsl code examples you provided...very helpful.  However, additional documentation is sparse in the Scripting Index, and appears to be non-existent in Scripting Guide.  Is there more documentation available on xpath?  I'd like to know what the format is for the input.  For example, what does the "//" do at the beginning?  And how should I format the rest of the input to get the displayboxes I need?
Thanks.
ms
This syntax seems to work:
y_axes = (lub << xpath("//AxisBox[@charID='2']"));
y_axes << scale(Log);
For xpath documentation, see for example w3schools tutorial on XPath
nikles
Thanks again.  Elegant.
