Neo
Neo
Send chart to journal using window name, not by using handle to chart?
Consider the following example script (a simplified  version of my actual problem)
//Scatt3D = dt << Scatterplot 3D( Y( :age, :height ), X Axis( :age ), Y Axis( :height ) );
include ("plotScatterPlot.jsl");
Window ("Big Class - Scatterplot 3D of age, height")<< journal;
//Scatt3D << journal
where plotScatterPlot.jsl contains
which generates a scatter plot in 3D with the window name
I can generate a journal using
Scatt3D << journal
But I need to generate a journal using the window name
which is not working. Could I please get some help in getting this to work?
(I am on JMP13).
When it's too good to be true, it's neither
Re: Send chart to journal using window name and not by using handle to chart?
The following JSL will generate a journal based upon the window name in JMP 13
Window ("Big Class - Scatterplot 3D of age, height")[outlinebox(1)]<< journal;
Neo
Neo
Thanks @txnelson. This works for the example I have provided. However, for the actual problem I am working on I am getting an error.
In my actual problem, the chart window (a heatmap) has a name.
"part16.08.02 6 - Graph Builder"
Running
Window ("part16.08.02 6 - Graph Builder, height")[outlinebox(1)]<< journal;
gives me the following error
expected character arg 1 in access or evaluation of 'Outline Box' , Outline Box/*###*/(1)
In the following script, error marked by /*###*/
Window( "part16.08.02 6 - Graph Builder, height" )[Outline Box/*###*/(1)] << journal
I get the journal created when I use
Window ("part16.08.02 6 - Graph Builder")[outlinebox(1)]<< journal;
It is using the name of the actual window.   Why are you using
Window ("MPD16.0008.02 6 - Graph Builder, height")
as the window name?
Neo
Neo
@txnelson  Sorry,  this is a typo
which I have now corrected in the post above, I am using
and it is working now (removed the, height). Thanks.
What is the purpose of
,height
