shoffmeister
Level V
Send a Message to All By-Groups in a Plattform
Hi JMPers,
in the multivariate plattform I would like to save all T2 values in my datatable via script.
Sadly I cannot figure out the command to save the T2-values in JSL. Further the report is using a by-variable so that I need to do something like "Hold CTRL pressed and left-click on T2-hotspot => Save T2" just in JSL.
Is that possible?
bc = Open("$SAMPLE_DATA/Big Class.jmp");
mlt = Multivariate(
  SendToByGroup( {:age == 12} ),
  Y( :height, :weight ),
  Estimation Method( "Row-wise" ),
  Matrix Format( "Square" ),
       Scatterplot Matrix(
            Density Ellipses( 1 ),
            Shaded Ellipses( 0 ),
            Ellipse Color( 3 )
  T²( 1 ),
  By( :age ),
  SendToByGroup(
  {:age == 12},
  Dispatch(
  {"Multivariate  age=12"},
  "Scatterplot Matrix",
  OutlineBox,
  {Close( 1 )}
  SendToByGroup(
  {:age == 13},
  Dispatch(
  {"Multivariate  age=13"},
  OutlineBox,
  {Close( 1 )}
  SendToByGroup(
  {:age == 14},
  Dispatch(
  {"Multivariate  age=14"},
  OutlineBox,
  {Close( 1 )}
  SendToByGroup(
  {:age == 15},
  Dispatch(
  {"Multivariate  age=15"},
  OutlineBox,
  {Close( 1 )}
  SendToByGroup(
  {:age == 16},
  Dispatch(
  {"Multivariate  age=16"},
  OutlineBox,
  {Close( 1 )}
  SendToByGroup(
  {:age == 17},
  Dispatch(
  {"Multivariate  age=17"},
  OutlineBox,
  {Close( 1 )}
ian_jmp
Level X
Re: Send a Message to All By-Groups in a Plattform
Alternatively:
NamesDefaultToHere(1);
dt = Open("$SAMPLE_DATA/Body Measurements.jmp");
dt << NewColumn("By", Numeric, Nominal, Formula(RandomInteger(1, 2)));
mv = dt << Multivariate(
Y(
:Mass,
:Fore,
:Bicep,
:Chest,
:Neck,
:Shoulder
By(:By),
Scatterplot Matrix(
Ellipse Color( 3 )
T Square(Save T Square)
ms
Super User (Alumni) ms
It's a little tricky. Try this:
//Make a list of all T2 objects in the compound multivariate report "mlt"
T2_all = Repeat(
    i = 0;
    {i++ ; Report(mlt[i])[Outline Box("T" || "\!U00B2")] << get scriptable object};,
    N Items(mlt)
//Send the save message to all T2 in one move
T2_all << Save T Square;
ian_jmp
Level X
Alternatively:
Y(
:Mass,
:Fore,
:Bicep,
:Chest,
:Neck,
:Shoulder
By(:By),
Scatterplot Matrix(
Ellipse Color( 3 )
ms
Of course! I started at the wrong end without looking back (although I had a feeling I was missing the obvious... )
