psundar6
Selecting data points across plots created from different tables
I generate two plots -
1) Variability plot from a stacked data table (B) [B is created from a parent table (A)]
2) Bivariate plot created from parent table (A)
These two plots are generated as a report in tabs. The problem I face right now is that since these plots are generated from different tables, points selected on either of the plots do not get selected on the other plot. Is there a way to link these two plots/tables so we can select points from one graph to reflect on the other?
An example JSL to do this will help.
Thanks.
Re: Selecting data points across plots created from different tables
Here is a way to get one of the charts(the bivariate), to select the values in both charts, but applying the same logic to both charts creates a timing issue.
names default to here(1);
dt=current data table("$SAMPLE_DATA/blood pressure.jmp");
dt<<new column("Row",formula(row()));
dt:row<<delete formula;
dtStack = dt << Stack(
	columns( :BP 8M, :BP 12M ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" )
biv = dt << Bivariate( Y( :BP 8M ), X( :BP 12M ) );
vc = dtStack << Variability Chart( Y( :Data ), X( :Label ) );
report(biv)[FrameBox(1)] << add graphics script(
	dtMat = dt << get selected rows;
	If(nrows(dtMat)>0  == 0,
		dtStack << select where(dtStack:row==dt:row[dtmat[1]]);
		for(i=2,i<=n rows(dtMat),i++,
			dtStack << select where(dtStack:row==dt:row[dtmat[i]], current selection("extend"));
gzmorgan0
@psundar6 ,
Another approach to your problem is to update table selections using table row state handler functions. Using @txnelson example, the script below creates these handlers.  Then any graph you create from this two tables will have linked selection states, unless a local data filter is deployed.
dt=open("$SAMPLE_DATA/blood pressure.jmp");
//Create functions to handle row state changes
//if dt selected row state is changed, change dtStack selected state
f1 = Function({a}, {dtr1={}},
      if(Is Scriptable(dtStack),
     	dtr1 = AsList(dt << get selected rows);
		If(nitems(dtr1)>0,
			dtStack << select where(contains(dtr1,dtStack:row) ),
		   nitems(dtr1)==0,
			dtStack << clear select
      ); //end if
//if dtStack selected row state is changed, change dt selected state
f2 = Function({a}, {dtr2={}},
      If( Is Scriptable(dt),
     	dtr2 =  Associative Array(AsList(dtStack:row[dtStack << get selected rows])) <<get keys;
		If(nitems(dtr2)>0,
			dt << select rows(dtr2) ,
		   nitems(dtr2)==0,
			dt << clear select
	); //end if
//create the row state handlers
rs1 = dt << Make Row State Handler(f1);
rs2 = dtStack << Make Row State Handler(f2);
 //any graph created from these two tables will be linked, unless a local filter is deployed
nw = new window("", HListBox(
    biv = dt << Bivariate( Y( :BP 8M ), X( :BP 12M ) ),
   )// end Hlist Box
gzmorgan0
@txnelson ,
small typo?
should be
If(nrows(dtMat)>0 ,
gzmorgan0
@psundar6 ,
		If(nitems(dtr1)>0,
		   nitems(dtr1)==0,
      ); //end if
		If(nitems(dtr2)>0,
		   nitems(dtr2)==0,
			dt << clear select
	); //end if
   )// end Hlist Box
