natalie_
Level V
Select a range of rows with variables
Hi everyone,
Is it possible to select a range of rows with variables?
This is what I have, but it found the maximum over the entire range:
vlower = lowerVoltage << get;
  vupper = upperVoltage << get;
  row1 = (vlower/10)+1;
  row2=(vupper/10)+1;
select_rows = row1::row2(dt2);
select_values = dt2:Idoff(select_rows);
id = maximum(select_values);
Re: Select a range of rows with variables
Natalie,
If I understand what you are asking for, I believe the jsl you want would be:
  row2=(vupper/10)+1;
select_rows = row1:row2;
id = maximum(dt2:Idoff[select_rows]);
dt<<select rows(select_rows);
natalie_
Level V
Thank you, so simple!   Thank you for helping me with more JSL syntax!
