buchea
Select Where evaluation using a variable
I'm having a strange issue when trying to use a variable in Select Where(). The following code works fine:
dt << Row Selection( Select Where( df:TestName != "pb" & df:BoType=="xxxx") );
Show(nrows(dt << get selected rows));
Prints in Log: Number of selected rows > 0 as expected.
But the following code fails completely:
sb="xxxx";
dt << Row Selection( Select Where( df:TestName != "pb" & df:BoType==sb) );
Prints in Log: 0
I'm completely baffled. Any help would be greatly appreciated!
Re: Select Where evaluation using a variable
I'm pretty sure that I have done this action without trouble. Perhaps simplify the message.
sb="xxxx";
dt << Select Where( df:TestName != "pb" & df:BoType == sb);
sb="xxxx";
buchea
This fixed it! Thank you!
