Seeking JMP Video: Chemical Quantification & Supply Chain Resilience
I recall a JMP webinar or video that demonstrated a method for converting diverse chemical characteristics into continuous, quantifiable data. This dataset was then used to identify promising alternative chemicals that were sufficiently similar to existing ones, specifically to mitigate risks from supply chain disruptions. Could you help me find this resource on JMP Community?
Victor_G
Re: Seeking JMP Video: Chemical Quantification & Supply Chain Resilience
Hi @dkraeuter_sunne,
I'm thinking about two Discovery Summit presentations which may be close to what you're looking for :
Increase Efficiency and Model Applicability Domain When Testing Options That Are at First Glance Mul...
Coding with Continuous and Mixture Variables to Explore More of the Input Space (2022-US-45MP-1103)
Do any of these presentations suit your needs ?
Victor GUILLER
Victor_G
Victor GUILLER
The first one was the presentation I was looking for. The second one was helpful. Thank you.
