wenwenzhou
Seek the probability of achieving the maximum and minimum pass rates
I have a set of data with already determined results. I want to use the known determination conclusions to infer what combinations of AB data_before can achieve the highest and lowest probabilities of passing the test.
Joyce_Pan
Re: Seek the probability of achieving the maximum and minimum pass rates
Hi Wenwen,
This is a binary response case. EDA and modeling can be applied to seek optimal combination for A and B.
Attached is the jmp file. You can run the scripts to see the results.
Since this is an imbalanced dataset with few "Fail" records, modeling with Logistic Regression, Generalized Regression and Random Forest in JMP PRO are not able to achieve good performance for predicting Y now. So I really recommend you combine the results of EDA and the models to narrow your process window. Also, I think confirmation experiments are needed to verify the parameters.
Best,
Joyce Pan
