Dennisbur
Search specific name by IF
Hello
I have set up a New Column "Pin Name"
and would like to add a number of PIN
It means if you contain gp_0 in the column "Test Name" it should be GP_0
or if you have contains gp_1 in test name it should be GP_1 in Column "Pin Name"
or if you have contains gp_11 in test name it should be GP_11 in Column "Pin Name"
I wrote the script
Column(dt,"PIN_NAME") << Formula ( If ( Contains( :TEST_NAME, "gp_0" ), "GP_0",
If( Contains( :TEST_NAME, "gp_1" ), "GP_1",
If( Contains( :TEST_NAME, "gp_10" ), "GP_10",
If( Contains( :TEST_NAME, "gp_11" ), "GP_11",
If( Contains( :TEST_NAME, "gp_12" ), "GP_12" ))))));
but I see the formula add GP_1 even I have gp_11 in test name.
so my question is, how I can set exactly name for searching?
mmarchandTSI
Level V
Re: Search specific name by IF
JMP will end the If() loop as soon as a condition is met.  Technically, "gp_11" does contain "gp_1"....
You could rewrite the If() loop backwards, like
If(
	Contains( :TEST_NAME, "gp_12" ), "GP_12",
But that's going to get really long and cumbersome, if you have a lot of GPs to check for.  Perhaps something like this would work for you.
Uppercase( Regex( :TEST_NAME, "io_(gp_\d+)", "\1", IGNORE CASE ) );
It look for "io_" followed by "gp_" and any number of digits.  "IGNORE CASE" is on so that "GP" will also satisfy the Regex.  If that's not the behavior you want, just leave off that part.
I worked this code up and it seems to work, and works pretty fast
names default to here(1);
dt=current data table();
dt << new column("PIN_NAME", character);
theRows = dt << get rows where( contains(:TEST_NAME,"_gp_"));
for each( {fndRow,i}, theRows,
	:PIN_NAME[fndRow] = word(1,uppercase(substr(:TEST_NAME[fndRow],contains(:TEST_NAME[fndRow],"_gp_")+1)),"[]")
