Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
I'm currently running a simple script to output contour plots from my data table. Is there a way of including the colour scheme I was to use and the fill area command as part of this script, as currently I'm having to do it for each plot individually/manually.
Can you provide more details on how you're producing the Contour Plot? Depending on the version of JMP you're using, both Graph Builder and Contour Plot are able to generate contour plots. However, their options are somewhat different.
PDB
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '19435' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '19435') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '19435') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
