GroupSquareWolf
Scripting: open all sheets from an Excel file
What is the syntax to open all sheets from an excel file without naming all the sheets?
This is the script log I got after clicking "Select all" in Excel Wizard. The specific excel file had 2 sheets name "Sheet1" and "Sheet2".
Worksheets( {"Sheet1", "Sheet2"} ),
I could not find help from Scripting Index either
Open( excelFilePath,
     <Worksheets( "sheet name" | {"sheet name", "sheet name", ...} | "n" )>,
Thanks
Re: Scripting: open all sheets from an Excel file
This simple syntax should work:
dt = Open( "Path\Workbook Name.xlsx" );
The variable dt will store a list of data table references when there is more than one sheet.
